Battery Indicator missing
(Topic created on: 03-18-2019 08:22 PM)
dp075
I facing issue that the battery percentage and indicator are accidentally pushed in corner and hidden sometimes on lockscreen after recently update
4 Comments
sukruth29
it will b present in settings
dp075
its turned on bt maybe its bug because it happens sometimes
Frankie19
U can use goodlock 2019 app for the sol.
dp075
I'm using goodlock.
