YoYoVishal8
12-16-2017 02:48 PM in
Sir please give an update and fix the battery drain problem or else give an option to reduce the display resolution on s6 edge. I think it is running on QHD that must be the main reason of S6 Edge drinking so much of battery and only lasting for 4 Hrs. Please Fix It.
6 Comments
MaverickSumit
12-16-2017 03:04 PM in
Keep your phone on Mid Power Saving, you will notice slightly less fluidity but an hour or more of extra battery life
YoYoVishal8
12-16-2017 03:30 PM in
thats ok even i know that but if samaung can give that feature of downgrading the display resolution then it will be better because the mid power saver puts background apps to sleep and creates problem in multitasking
MaverickSumit
12-16-2017 03:35 PM in
that's next to impossible. we won't get that
YoYoVishal8
12-16-2017 03:47 PM in
why?
YoYoVishal8
12-16-2017 03:49 PM in
i mean note5 got that feature in the update why not s6 edge running the same processor as note5
admin_
12-17-2017 12:58 PM in
"Thank you for Joining Samsung community. We would recommend taking some troubleshooting steps to further isolate what you may be experiencing.
Find troubleshooting steps on provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let the community know what steps you have taken and if you have noticed any changes or improvements. This will help the Community to provide you steps without repeating any steps you may have already taken. "
Be sure to hit ♡ when you find an answer that works for you.
