01-13-2025 04:31 AM in
Galaxy S- Mark as New
01-13-2025 06:56 AM (Last edited 01-13-2025 06:57 AM ) in
Galaxy SSimple steps to save battery at the cost of sacrificing luxury
1 Enable Power saver
2 Enable performance mode light
3 Enable adaptive brightness
4 Disable AOD
5 Enable extra dim
6 Change display to natural
7 Record videos in FHD
8 Restrict gaming to HD or FHD and slower frame rate
9 Switch to dark mode
10 Disable near by device scanning
11 Disable WiFi scanning
12 If 5G is unavailable change network to LTE/3G/2G
13 Allow the battery to drain completely and recharge,say once a month.
14 Enable auto restart
15 Run device care
16 Disable apps running in back ground.
17 Uninstall bloat ware that came with your phone,eg. Spotify,LinkedIn etc.
You can mix match the steps above and arrive at a usage based on your needs.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
01-13-2025 07:15 AM in
01-13-2025 08:53 AM in
01-13-2025 08:54 AM in
01-13-2025 11:03 AM in
01-13-2025 05:02 PM in
Galaxy SDear Samsung Member,
We regret to hear about your experience with our product.
To fix battery drain issue please use the link to perform some easy troubleshooting steps: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps:
3. If you do not remember then reset (Forgot password) your Google account.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
