10-12-2024 03:33 PM in
Galaxy S- « Previous
- 1
- 2
- Next »
10-12-2024 04:04 PM in
Galaxy S- Mark as New
10-12-2024 04:05 PM in
10-12-2024 07:19 PM in
10-13-2024 02:00 PM in
Galaxy SDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
- « Previous
- 1
- 2
- Next »
