S23 fe Battery Drain
(Topic created on: 12-19-2024 11:16 AM)
Sachin9994
After Updating December 2024 Security Patch Update. Battery Draining continuously. S23 fe is worst Fe series phone ever Shame On Samsung. Not solving Battery problem in s23 fe.
12 Comments
Biplab9
Yes, I need optimization.
KumarUjjawal
Bro i updated via smartswitch my battery is working 💪 i.e it is now like 12 or 18 hours earlier it was 5 or 6 hours.1734588201595.jpg
Sammy_23fe
How ?
Sammy_23fe
I want that too as I'm getting 4 to 5 hours
Sammy_23fe
You are using on power saving mode ?
KumarUjjawal
Bro no settings change before and after update.. only change is the software..
Sammy_23fe
How i m also using dec patch update
KumarUjjawal
see this no settings change .. its December patch . .. 1734674168124.jpg1734674225447.jpg
SK818
How did you updated via smartswitch
