Battery drain faster on s23 post December security patch update
(Topic created on: 12-18-2024 07:49 PM)
robinrose
Anyone else's S23 battery draining faster since the December security update?
7 Comments
AstroDXB
Yes
hpsingh75
Yes
ajith0544
From past 2 months I'm noticing this
khan69
For Samsung Galaxy S23 Ultra users experiencing unusual or excessive battery drain, I've shared a Twitter post about this problem. I would appreciate it if you could retweet it.
https://twitter.com/arshad3011999/status/1864634722279624997?s=19
khan69
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
SoumyaSagar
Yes man, same thing happening to me as well. Draining like anything.
