dhruvil16_199
11-27-2022 08:34 PM in
Since past few days, battery of my S20 FE is draining faster as compared to before. Overnight battery goes down by 10%(Without using). So, its my request to send update as soon as possible and solve this issue.
PS: My phone is 6 moths old and battery is in perfect condition, it must be something in software.
4 Comments
Mnkg279
11-27-2022 08:48 PM in
Try force stop apps that you do not use often. Also can try auto optimize daily or put apps to sleep that are not used for long (both are auto enabled by default if not disabled).
user00xman
Bro pls follow my account and you will see there how to fix more battery usage and high background data usage.
AkshayParadkar
11-27-2022 10:21 PM (Last edited 11-27-2022 10:24 PM ) in
Turn off always on display. Aod consumes alot of battery. Also turn on auto-restart option from device care app. Reboot your device atleast twice a week. Also turn on auto clean junk files from device care & set cleaning frequency as daily & also turn on close apps to freeup ram memory option
If you upgraded android operating system like from android 11 to android 12 then clear cache partition from recovery mode.
Sáyân15
11-27-2022 11:35 PM in
Just now you got One UI 5 update, so let the system optimize itself for the new OS...
Once it optimizes & learns your usage patterns, you'll get gd battery life :)
