Battery Drain Problem
(Topic created on: 08-29-2024 08:01 PM)
Not applicable
Whose phone is draining battery quickly after the August security patch update? My phone's battery is draining very quickly.
5 Comments
RĀJ
Hi. It is always helpful to clear the cache portion of the phone through the recovery partition after every update. It will be helpful
Not applicable
Ok! I I will try it.
RĀJ
In case you are not sure how to it, here are the steps:
connect the phone to a pc/laptop via USB. Then turn off the phone while connected. Then if you're laptop is on and phone is charging via it, it will show the battery charging animation in off state, wait for it to load fully with percentage, then press vol up +power button together, when you see the samsung galaxy boot logo let it go, if you had follwed the above steps correctly you should be in stock recovery. There use vol down key to select wipe cache partition, when you chose it , it will again ask no and yes. Press yes and reboot.
Not applicable
Battery Drain problem solve after clear cache
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
