Battery Dain automatically in s24
(Topic created on: 12-21-2024 08:35 AM)
KD50
I have purchase s24 before 2 days ago but battery drain fast in just 2 min 1% battery dain if is in lock condition mode
Internet off condition as well as display off condition
#samsung care please support for resolve this issue
5 Comments
-Aneesh
Oen Samsung Members app >Support >Check Diagnostics..
goodthings
Your's device is very new so please give it's some time. After some time and after some updates all is well. So please don't bothered about this issue now. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
goodthings
Congratulations 🎊 for your's S24. Thanks.
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that when initially using the device, battery consumption may be rapid due to learning battery usage patterns and application of performance optimization. It will stabilize after a certain period, but if still facing issues, kindly perform the following steps to resolve your issue.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
