Resolved! Solved
Battery Bulging?
(Topic created on: 10-25-2021 11:05 PM)
GeojiGeorge
Hello, Recently I noticed a small gap between my back panel and aluminium frame of S10.
Would that because of Battery Bulging??
Resolved!
GeojiGeorge
Is there any app or anything to check health of battery. I just wanna know if it got swollen or not.
AYush2313
You can check through Samsung members app Go to > Get help > start > battery status .. Mark this as a solution if you find this helpful
GeojiGeorge
It says Normal.
Life: Good
Not sure though if it's accurate 🤔
AYush2313
Send me screenshot and tell about your opinion what you feel about your battery life
GeojiGeorge
AYush2313
Don't change your battery it's good
GeojiGeorge
Thanks mate. Please check the graph too
GeojiGeorge
AYush2313
Checked ... Just ask them to change your pasting not battery if they are not then call on Samsung care
If you like all please mark all reply as a solution
GeojiGeorge
It's the service center I went. He said me that, its very dangerous and the battery buldge can crack the back glass blah blah. But I couldn't find any swelling in the back glass. It's all a slight gap. Also he said I don't have much time, only around 15days.
I don't know what he gain from me changing the battery or not. He's getting salary on daily basis right?
