Resolved! Solved
Battery Bulging?
(Topic created on: 10-25-2021 11:05 PM)
GeojiGeorge
Hello, Recently I noticed a small gap between my back panel and aluminium frame of S10.
Would that because of Battery Bulging??
AYush2313
Checked ... Just ask them to change your pasting not battery if they are not then call on Samsung care
If you like all please mark all reply as a solution
28 Comments
VISIT NEARBY SERVICE CENTER AND GET INSPECT YOUR DEVICE ONCE
GeojiGeorge
I did, they said me the battery got bulged and it has to be replaced.
But I'm confused if that's a trick to make sale!!
IT'S LIKE 50% 50 % SITUATION !
IF IT'S BEEN LONG TIME OF DEVICE BETTER TO REPLACEMENT OF BATTERY
GeojiGeorge
Okay. So, those guys does such tricks? Anyways it's been a year.
THEN I DON'T THINK THAT BATTERY GOT SWALLOW IN A YEAR
MUST BE THAT BACK PANEL GETTING OFF DUE TO OTHER REASON
AS WE CAN'T KNOW ACTUALL THINGS BEHIND THIS
AYush2313
Your waterproof pasting is gone from back
GeojiGeorge
Yeah. Also they said if I pay 2050inr they'll replace the battery and seal back with WR rating.
AYush2313
Is your phone was heating badly ??
GeojiGeorge
Nope not very much. But it's been a year
