Auto restart problem
(Topic created on: 06-22-2025 06:27 PM)
furkanmeo
My device is frize and restart automatic some time he run continue and some and some time he auto restart again and again
8 Comments
Is this happens automatically or only happens while using some specific apps
furkanmeo
Automatically
goodthings
Kindly reset factory data with backup then try to it's again. If not resolves then go to service center for check and resolves this issue. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
furkanmeo
I try but not satisfy
goodthings
Your's most welcome to here.
itzmesam
Your phone have bug after installed oneui 7 so it automatically restart to solve issues
itzmesam
You can report to Samsung
cs_member10
Dear Samsung Member,
We would request you to kindly perform the following steps to resolve your issues.
● Galaxy device auto restart issue:
→ Kindly use a genuine Samsung charger.
We always recommend using a genuine Samsung charger for charging your device.
→ There are two methods to disable the auto restart function.
1- Tap on Settings> General management>Reset > Disable Auto restart (if enabled)> Auto restart disabled.
2- Tap on Settings> Battery and device care> Three dots> Automation> Auto restart at set times if enabled.
→ If you are facing this issue after installing any new application then uninstall that application.
Tap on Settings> Apps > desired app> Uninstall> Ok.
● Galaxy device freezing issue: ● Check space availability: Settings > Battery and device Care > Storage.
● Check RAM in your device: Settings > Battery and device Care > Memory.
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Clear cache memory of a particular application: Settings > Apps > pick the app > Storage > Clear Cache.
● Close Background Apps.
● Remove third party application.
● Remove memory card: Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
● Remove third party accessories.
● Kindly disable Power saving mode( if enable).
● You can reset your device by following the steps:
3. If you do not remember, then advise to reset (Forgot password) his/her Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tab on Factory data reset to reset your device to its factory default settings. This will erase all data, including files and downloaded apps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
