Auto call recording does not work
(Topic created on: 08-10-2023 07:20 PM)
Bhagatpnv
Auto call recording for specific numbers is not working in S22 ultra.
2 Comments
sarnandu
check in numbers to record
cs_member10
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same and please follow the easy troubleshooting steps which might help to solve the issue.
Note: Steps may vary as per device and operating system.
Note: This feature may not be available in all Samsung Galaxy smartphones.
Method 1: Automatic
Go to Phone app>>Three dots>>Settings>>Record calls>>Auto record calls>>Enable
you can choose the preferred option from the following:
• All calls
• Calls with unsaved numbers
• Calls with specific numbers
Method 2: Manually
Ongoing Call screen>>Three dots>>Record call
How to view Recorded Calls
Please follow the given below steps to view recorded calls
Step1: Phone app
Step2: Three dots
Step3: Settings
If the call recording feature does not work, follow these given steps
Note: If you are using Wi-Fi calling then you won't be able to record any calls.
Step1: if still problem persists, then perform ‘Reset app preferences
Go to Settings > Apps > Three dots > Reset app preferences > Reset
Step2: Restart the device
Step3: Reset the settings
Go to Settings > Settings > General Management > Reset > Reset all settings > Reset settings
Step4: Software update
Go to Settings > Software update > Download and install > Download > Install now
Note: Steps may vary depending on the OS & device model.
Step4: Record calls
Step5: Recorded calls
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
