06-06-2024 03:51 PM in
Galaxy S- Mark as New
06-06-2024 07:11 PM in
06-06-2024 07:39 PM in
06-06-2024 07:42 PM in
Galaxy SIt cannot be fixed with software update the light sensor is designed like this man it can only get 1500 nit max under direct sunlight other wise it will cause display burns
06-07-2024 07:58 AM in
Galaxy SDear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
