Android system is not optimised
(Topic created on: 01-16-2024 01:30 PM)
peterpgerald
I am facing issues with my touch from a few days and today I started getting this message. What needs to be done? Will software update help or I need to do something specific?
5 Comments
AJAB_MORIA
1). Check for the latest updates regularly.
2). Reset all settings and restart the phone(if possible).
goodthings
Reset factory data with backup and also software update.Thanks.
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue.
Remove the screen protectors and cover from the device once and check the issue after restarting the device.
Kindly check if the device's touch screen is physically damaged: The phone touch screen could stop working due to physical damage.
Physical damage: The touch screen is broken or damaged. High temperature, cold, moisture, magnets, and static electricity can all damage the touchscreen of Android phones. If your screen is damaged, you need to carry your device with its ''original accessories'' to the ''Samsung authorized service center''.
If your screen is not damaged, Restart the phone by pressing the Power button and then tap on Restart.
Note: If you use the Fingerprint security feature, the phone will require your backup password to unlock after rebooting.
How to restart the device: Press & hold the power key> Restart> Tap again to Restart.
Kindly check if you are using a memory card on your device.
If you are using the memory card on your device. we will advise you to safely remove it from your device. For this follow the below steps:
Step 1: Before removing the memory card, first, unmount it for safe removal.
On the Home screen, tap Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount. Insert the ejection pin into the hole on the tray to loosen the tray.
Note: Ensure that the ejection pin is perpendicular to the hole. Otherwise, the device may be damaged.
Step 2: Pull out the tray gently from the tray slot.
Step 3: Remove the memory card.
Step4: Insert the tray back into the tray slot
Note: Please ensure that the memory card is not removed while the device is transferring or accessing information. Doing so can cause data to be lost or corrupted or damage to the memory card or device.
Samsung is not responsible for losses that result from the misuse of damaged memory cards, including the loss of data.
You can check the device in safe mode and for the same mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Amitkrsingh
I am facing issues with my touch from a few days and today I started getting this message. What needs to be done? Will software update help or I need to do something specific? 1754963089105.jpg
pritamHaazra
Android System isn't optimised for the latest version of Android. Screen touches may be delayed or not recognised |
Solve this problem ?
