Always on display or AOD in Samsung galaxy s6 edge
(Topic created on: 04-29-2017 04:39 PM)
kunal007
When i try to install AOD apk... Why is it showing (conflicts with an existing package by the same name) That's means the AOD service is already installed in s6 edge.... It has to show not installed or error..... but its showing this... If there is AOD available we have to just find that.... dd01f9d4-0cdc-45dd-ab60-f975e7ed60e3.jpg
8 Comments
Prince
Try to download latest version of AOD from apkmirror.com, hope u'll get solution
kunal007
I downloaded the latest version From sam mobile
Mesbah3575
any downloaded Samsung's AOD not working on galaxy phone
I have s7 edge i had tried
GouravC
first of all you need to download its framework
Monika2
How to get that framework then. Actually I have uninstalled some system apps before via adb but none of them seems to be related to Aod. But please can you tell specifically which framework do I need, should I download something from web? Or install any particular
system app back
GouravC
just same as samsung pay
Samsung_India_
Thanks for your feedback. As of now AOD feature is not working in Samsung S6. We will notify you any update in this regard via FOTA. Menu> Settings> About Device> Software Update> Auto Update> Enable it.
balu147
add shortcut on hme of ur apk frm file manager . reboot ur mobile. quickly unlock ur mobile and install app. thgh app installed s6 kernal version stops aod from running.
