10-24-2025 07:13 AM (Last edited 10-24-2025 07:14 AM ) in
Galaxy S- Mark as New
10-24-2025 08:25 AM in
10-24-2025 11:37 AM in
10-24-2025 12:54 PM in
10-24-2025 04:20 PM in
Galaxy SDear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
▶ Galaxy device fingerprint issue: ● Kindly restart the device: Press the power and volume down keys simultaneously for a few seconds.
● Kindly remove the current fingerprint and set up the fingerprint again. When you touch the sensor to set up a fingerprint, make sure you set the entire fingerprint, including the outer area of your fingertip. Setting the entire fingerprint area enables successful fingerprint recognition with any grip.
● Please follow the below steps to remove the Fingerprint:
Path: Settings> Biometrics and Security> Fingerprints> Fingerprint1> Remove> Remove again to confirm.
● Please follow the below steps to set the Fingerprint:
Path: Settings> Biometrics and Security> Fingerprints> Add Fingerprint> Scan your fingerprint>Place your finger on the sensor, then lift it off when you feel a vibration> Continue> Reposition your finger each time to capture the edge of your fingerprint> Done > Fingerprint added successfully.
3.If you do not remember password, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tab on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
