About battery drain issue
(Topic created on: 09-11-2024 08:01 PM)
Mont1
Samsung has initiat this problem and solve this problem of battery drain issue in Samsung galaxy s24 series
8 Comments
adit_mikku_
Try this steps-
1. Turn off nearby scanning.
For that - go to settings>connection(scroll down)>more connections>turn off "nearby scanning".
2. Turn off print services.
For that- go to settings>connection(scroll down)>more connections>click printing>turn off default printing services.
3. Adjust screen refresh rate to 60hz.
4. Use black theme for amoled or oled. displays, it will save more power.
5. Turn off data roaming.
For that- go.to settings>mobile networks> turn off data roaming.(Tip- if u want to save more power turn off volte call feature just below that.)
6. Go to settings>battery and device care>battery(scroll down)>more battery settings>enable adaptive battery.
●Tip(Charging ur phones battery from 20-80% will increase ur battery health 🔋. Don't charge it full. Turn on ("protect battery") in settings so that ur phone will automatically stop Charging at 85%.
Cleaning phone caches weekly will improve device efficiency.
Mont1
How to clean chtche
adit_mikku_
Hey, you can just go to phone settings> apps> select app>storage> scroll down you will find cache( don't clear data)> clear
goodthings
Mont1
Okay
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
AviNote
Kya matlab hai itni restrictions laga ke phone use karne ka fir?? I have paid 1.25 Lakh rupees Just to use my phone at 60hz or in dark mode????
