25w power bank ?
(Topic created on: 12-21-2021 12:01 AM)
kl30wolf
Is there any powerbank in India which we can provide 25w fast charging for samsung device ?
kl30wolf
Ye since that powerbank delivers 30w i thought it may give 25w to S20FE but it turns out to be 18w only right ?
Swetabh_Singh
Yes... i can't exactly say its 18 watt but i have used both 15watt charger and is currently using 25 watt so for me my powerbank charges faster than 15 watt and slower than 25.
Also the PowerBank is slim and rounded at edges as compared to others so its easy to carry too...
Also it charges the device descently like no heating issue or anything as such.. you can go for it if you want a good powerbank, otherwise there isn't one available with 25 watt...
There is one samsung PowerBank you can find offline but don't go for it.. it says 15 watt but maxes out at 10..
SachinDodake
Bro..plz share the link to buy this powerbak
Swetabh_Singh
Amazon:
realme 10000 mAh Power Bank (Fast Charging, 30 W) Black https://www.amazon.in/dp/B08T9PGTFT/ref=cm_sw_r_apan_glt_fabc_TVN5FB399JPEG4ZTERJS
RealMe Official Site:
https://buy.realme.com/in/goods/225
Flipkart:
Take a look at this realme 10000 mAh Power Bank (30 W, Fast Charging) on Flipkart
https://dl.flipkart.com/s/TsEFZxuuuN
Also its Available Offline, you can buy it from any Realme retailer.
SachinDodake
Thnx bro
kl30wolf
But is it safe to charge a phone with 25w max voltage with a 30w power bank or charger ?
Swetabh_Singh
The PowerBank have certified PD and QC protocols for charging... and on top of it it also have a electrical protection monitoring... so it wont charge your phone at 25watt... this powerbank support few charging standards UPTO 30 watt...
Which basically means that it will prove the current to the phone as per the phone requires it... you kinda say it Smart charging... but its nothing but basically PD and QC protocols which samsung supports..
Also customer care will deny you for that, i fact they will suggest you to go for Samsung 10 watt because they are told to do so...
kl30wolf
Ey no no they said it's nothing bad to use a 18w mi powerbank but better not to use 30w powerbank. Maybe they are unaware of the protection monitoring powerbank these days have
kl30wolf
No even if the phone supports 25w fast charging people are getting only 18w or 15w supply from this realme powerbank. Seen in the answers for the questions on Flipkart
Swetabh_Singh
The Charging speed wether you use a wall charger or powerbank depends on the device and its temperature.... see i have posted the specs for samsung 25 watt charger... it also have variable power output... since when device heats up the powerbank or the charger just reduces the current and increses the voltage... and does vice versa when its cool...
See the lowest output of 25watt charger is 3.3V 2.25 A which is equal to 7.5 watt... but that doesn't mean that 25 watt charger always charges the phone at 7 watt... it does in extreme conditions like very high device or battery temp or when the device is under heavy use or when the device is about to be fully charged... also if you see they have put a Voltage range between 3.3 to 11 watt at different Current output... and that is how it keeps the optimum charging.. like the watt keeps fluctuating between 7 to 25 watt... and also fun fact... after 90 percent charge every device just gets back to low charging... of you don't believe me try using some Charging Test app you'll get to know...
You can also test it yourself.. when you heavily use your device, connect it with a chager it will take time to charge... and when you doesn't use a device then connect it with the charger it will charge fast... also there are multiple factors of heat that alters the charging speed like the temp of charger or powerbank, temperature of Device battery, temperature of device SoC, ambient temp etc...
