25w power bank ?
(Topic created on: 12-21-2021 12:01 AM)
kl30wolf
Is there any powerbank in India which we can provide 25w fast charging for samsung device ?
26 Comments
This is highest recharging powerbank.Screenshot_20211221-000412_Samsung Internet.jpg
kl30wolf
I think it will only deliver 15w or 18w to samsung devices
Swetabh_Singh
Nope 10 watt for Samsung. Actually samsung had restriced few powerbanks, wireless chargers and Adapters to charge at 10 watt. This is unfortunately one of them.
If you want to go for MI then go for MI Hypersonic...
It have 45 watt Laptop power Delivery and upto 50Watt for Mobiles... but unfortunately Samsung just support it under 20-15 watt..
kl30wolf
Then there is no purpose of that na ? I now have a mi 2i which charges at the same rate as a samsung 15w charger
Swetabh_Singh
Actually... tbh i was also thinking to buy this Mi Hypersonic one... but one of my friend recommended me this Dart one... n actually its good... m happy of what i am getting out of this... i mean this do charge my device almost twice... and at descent speed without heating...
kl30wolf
May be in the long run will it affect phones battery ?
Swetabh_Singh
Any type of Fast Charging wether its 15 watt or 25 watt harms the battery for long run... thats actually a different thing and it depends on the Battery Cycle... nowdays powerbanks have different protection systems such as power surge, orver current protection, under and over voltage protection... basically nowdays powerbanks actually work as same as the wall adapter...
Unless you get some local copy... the branded ones are good..
Swetabh_Singh
Nope... but i would suggest you to go with Realme Dart power bank... it have a Power Delivery option, for samsung it shows that it charges at 15 watt (s20 fe) but actually my phone takes 1 hour 35-40 mins to charge completely... where as with 25 watt it takes 1hr 15 mins appox... i guess it goes upto 20 watts...
Also i am suggesting this powerbank cuz it support other QC Quick Charge, Dash Charge, Dart Charge, Vooc Charge, phalana Charge and Dhimaka Charge...
Also it support the laptop charge of you have type c charging port...
