note 9 charging problem
(Topic created on: 09-19-2019 11:09 PM)
mickey2005
Galaxy Note
I got note 9 less than a year ago .... It has started heating up on left side on normal usage and also charging is very slow !
I am scared
11 Comments
Not applicable
Galaxy Note
do you set it in first charging option?
mickey2005
Galaxy Note
sorry i am not able to understand that sir ...
Not applicable
Galaxy Note
aap ne kya settings me jake first charging ki option ko on kia?
mickey2005
Galaxy Note
first charging ? ye kya hota hai ... you mean Fast charging ?
Not applicable
Galaxy Note
Not applicable
Galaxy Note
oh ya I mistaken fast charging
Not applicable
Galaxy Note
sorry for spelling mistake
Not applicable
Galaxy Note
the problem is nothing but your software fault.....see,each and every time we do a little mistake,that mistake is ,especially for Samsung ,we just download new firmware through our own network or wifi...it's good, no doubt about this...but sometimes it make problematic..when your network is little bit slow , ..during updating a new security patch can skip your important file...this issue called as mis files skip procedure....if it's happend then you can eligible to get issue like....battery drain, ui lag,poor camera performance etc...so my suggestion is to ,just flash same previous firmware from odin or through Samsung service center..instead of downloading it by your own network....and when you will get next security patch update..then just turn on download booster option from your connection settings....definitely your problem will be solved 👍👍👍👍👍
mickey2005
Galaxy Note
thank you
