note 8 battery problem
(Topic created on: 12-29-2017 08:58 AM)
fy
Galaxy Note
have any one experienced this issue
9 Comments
Galaxy Note
Dnt make it reach zero percent anytime.... We should always charge between 30 and 80% to hve long battery life upto 3yrs
note08
Galaxy Note
are u sure
Galaxy Note
Yes.... My S7 edge has 3600mAh battery and till nw after 1.5yrs it's battery backup is OK.. 8 hrs screen on time... I charge always above 30%.. Very rarely I charge at 15% carry some power bank with u always
Lauki
Galaxy Note
It has become a global problem now. Hope Note 8 doesn't follow its ancestor's footsteps, otherwise it would be a 2nd disaster for Samsung
Lauki
Galaxy Note
It's a typical battery or a phone stage where neither the battery nor the phone allows charging. I personally had faced such issue with my HTC earlier. Now it's dumped as the service centre also couldn't do anything with it.
Be careful my fellow Note 8 people!
pvrksunil
Galaxy Note
this problem is mainly facing on snapdragon processor based note 8 in usa but not in india
Lauki
Galaxy Note
Yes, but the Exynos on Note 8 in India is faced with restart and some serious hanging issues while using Microsoft excel files. Even a single tab excel file causes this issue, which is totally frustrating.
admin_
Galaxy Note
Thanks for being with Samsung and for sharing your concern. We would like to inform you that there is no such issue occur in the device. If any issue persist Samsung will provide best possible resolution for the device issue.
Be sure to hit ♡ when you find an answer that works for you.
Lauki
Galaxy Note
But we already are facing the issue
