3 Comments
giriabhi
05-26-2018 01:05 PM in
Galaxy Note
check background applications.
try to drain the battery and charge it fully before using
check your 3G/4G connections
check wifi connectivity (switch off when not in use)
refer to battery graph for usage information
take to service centre
RamBelkar
05-26-2018 01:12 PM in
Galaxy Note
what is additional useful function in c7 pro
admin_
05-28-2018 01:03 PM in
Galaxy Note
We apologize for the issue facing in the device. We would recommend you to follow some troubleshooting steps in order to further isolate what you may be experiencing in your device. Find the troubleshooting steps on the provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let us know what steps you have taken and if you have noticed any changes or improvements as this will help the Community to provide you further troubleshooting steps without repeating any procedure which you may have already followed. Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
