note 4 problem
(Topic created on: 04-20-2017 07:52 PM)
arsh
Galaxy Note
hai sir I want to give a very bad feedback my 3 friends r using note 4 and now I'm also using note 4 , but when we upgrade a phone to marshmallow, phones r getting heat and getting hang and mother boards going to die. y this concerns r going on this phones please reply me. 3 phones we have throud out. and in Samsung service the cost of mother board is above 10000k they r sying what we should do please reply give me a solution.
9 Comments
MaverickSumit
Galaxy Note
10000K?? 😫😫
arsh
Galaxy Note
's 10000k
arsh
Galaxy Note
no replies from Samsung .. team ????
noteuser
Galaxy Note
hi ! even I am using Note4 form past 1 and half year there is absolutely no problem even after updating it to mashmallow. yes it heats up but never lags or hangs. try factory reseting
arsh
Galaxy Note
I done all ....
Samsung_India_
Galaxy Note
We apologize for the inconvenience caused. We would suggest you to kindly send us your complete details on provided link http://www.samsung.com/in/info/contactus or mail us on [email protected]. We will do our best to resolve your issue.
Sagarbhoir
Galaxy Note
He is correct. I also use Note 4 and my friend too use note 4. we faced very identical problems. first the phone got into the reboot loop where phone restart in loop until battery dies. we both changed our batteries and it's fixed. now new problem. phone gets switch off suddenly and won't start until charger connected and when we remove charger phone dies and don't restart. we both had same problem back to back first my friend took his phone to the service centre they said need to replace motherboard which would cost 19500. and then it was my turn and same cost to replace motherboard. I am a samsung person and never expected such a poor performance from the flagship device. I am going to launch official complaint via this app. but just read this and replied.
sachinsharma
Beginner Level 5
Galaxy Note
Hi Samsung, can you please look into this as I'm also facing the same problem after marshmallow update. I believe you should have test every update before launch. Also please let us know if you are not able to solve these issue.
As I heard you are not providing us with the nougat update for Note4 (good decision cause you guys can't) so please suggest if we can degrade our Note4 from marshmallow to lollipop.
I have reviewed most of the post on Note4 and many are unanswered, are this all your service for your products?
Sriv
Galaxy Note
many note 4 users have started getting this issue recently in the last month. Samsung needs to do something about it asap. I was planning to buy note 8 but lost confidence in Samsung
