note 20 ultra wifi issue
(Topic created on: 10-08-2020 11:50 PM)
ksrdj
Galaxy Note
Note 20 ultra serious wifi issue.  Wifi stops working telling no connection even though it is perfectly working with other devices including my note 10 plus . I have even raised the ticket to samsung . They acknowledged its a known issue and they are trying to resolve and will give update in the future.  It is seriously irritating to find that it can't do basic stuff like connecting  to wifi ..I have been the premium user of samsung mobile for around a decade ...and I feel this is the worst bug ever .
Anyone solved this issue ?? Any suggestion ?
27 Comments
Sweick
Galaxy Note
this didn't work, any position about software update to fix it?
i got my Galaxy note 20 yesterday and i can't use my wifi since then.
this is a serious problem, is an expensive phone to have problems like that.
ksrdj
Galaxy Note
use a wifi extender ...near by where u usually use..like in your room . then only it works
Koskam
Galaxy Note
I have a Note 10+ and I'm having the same issues. I've tried everything but a factory reset. I remember having this same issue when this first came out and I needed to get a replacement. Frustrating.
guest20
Beginner Level 4
Galaxy Note
S20, same problem here
Earthairfire
Beginner Level 3
Galaxy Note
I have the same issue on 2 different S20+ phones. iPhone, iPad, laptops etc all work fine.
Seems to be possibly as issue with mesh networks and auto switching between 5ghz and 2.4ghz frequency using the same SSID. Unfortunately most modern mesh systems operate the same way with one shared SSID
Seems like a possible work around for some reason is to disable 'google location accuracy' under settings > location. No idea why this makes a difference but many people are reporting this solves the issue for them. I'm testing it myself and so far so good. Shame it means photos now have no location :(
Jishu19
Galaxy Note
I have the same problem on my s20 .Though there are wifi signals available on other devices,but it shows blank in my s20. it can scan any wifi nearby with weak signals
D4saken1
Galaxy Note
I found this on Yutube from Sakitech. I set this up on my phone and I have had the wifi on now for 7 hours and have had no drops or interruptions. Here is the link please share it and help everyone.
https://www.youtube.com/watch?v=C0hyK9B0yN0
Get the wallpaper here: https://sakitechonline.com/2020/12/31/stunning-samsung-galaxy-wallpapers/ In this video, I will show you an awesome tactic to extend the battery life of your Samsung Galaxy Smartphone. This could be any Samsung, Note 20 Ultra, S20, A71, A51, Note 10, etc. It also works on ...
ksrdj
Galaxy Note
Thank you . After new update I don't have any wifi issues
