note 10 plus battery
(Topic created on: 02-20-2021 11:55 AM)
Kunwar868
Galaxy Note
Note 10 plus shows screen on time of 3+ hours in  100-60 % ie in 40% but in remaining 60% it just last for screen on time of 1 hour hardly and gets dead in nearly about 4 hours , what could be the problem and what can be done to solve it
It's a Exynos 512 gb variant .
14 Comments
Galaxy Note
Get your phone checked in service centre.
Meanwhile you can also performed battery health checkup in Members App. Members app》 Get help.
Kunwar868
Galaxy Note
how to check battery health ??
Galaxy Note
Goto Members app> Get Help > Phone Care > Interactive Checks.. There select Battery .
Kunwar868
Galaxy Note
it shows this .
Galaxy Note
Then it seems everything is fine. Try Resetting your phone and see if the problem is solved.
Kunwar868
Galaxy Note
I have done that I factory reseted the phone 2 days before but the problem is still the same
Galaxy Note
One last thing before visiting service center, Update your phone using Smary Switch on PC/LAPTOP.
Kunwar868
Galaxy Note
what is smary switch ?
Galaxy Note
Smart Switch is a Samsung application for backup/restore and updating the software of Samsung phones.
The main difference is, With smart switch the whole firmware is installed on your phone and with OTA only a patch (small portion of OS) is installed.
