note 10 plus battery drain
(Topic created on: 01-29-2020 12:44 AM)
itsmecooldude
Galaxy Note
After android 10 update my mobile battery drains too fast.
15 Comments
YFiiT
Galaxy Note
i Agree
batking33
Galaxy Note
indeed
msingh48
Galaxy Note
use medium power saving mode,put all apps to sleep mode,use auto brightness,use tap to show AOD option then u will get 7 hours SOT and normally 2 day battery backup with medium to heavy use.
itsmecooldude
Galaxy Note
i did same as u said. still same issue. before update i used to get 2 days. after update not even 24 hrs
itsmecooldude
Galaxy Note
is there any option to downgrade software
msingh48
Galaxy Note
no need to downgrade. If u have done all things mentioned above then clear cache from recovery mode then applied above said things.
msingh48
Galaxy Note
I also suggest u to switch off location and auto sync.Swich off mobile data & wifi when not needed.
itsmecooldude
Galaxy Note
im a little heavy usage type. i get almost 750 calls per day. mobile data is of no use to me. 70% it wil be turned off. how to clear cache from recovery
msingh48
Galaxy Note
I upgraded to January patch & everything is fine.
