Auto call recording not happening for Wifi calling.
(Topic created on: 01-29-2020 05:20 PM)
prakashks
Galaxy Note
I just saw that auto call recording is not happening if the newly enabled feature wifi calling is active. Is there a way to record them natively without any additional app? Maybe a software upate should fix it.
4 Comments
mayankmorya
Galaxy Note
yes
Galaxy Note
the wifi calling use a separate algorithm which you cannot record using your native (inbuilt or preinstalled) call recorder so you have to wait for update or you can use another app
Aashish
Expert Level 4
Galaxy Note
Currently Wi-fi calling isn't available in default Samsung call recorder.
vinayshah
Galaxy Note
I already reported the issue here
