low incoming call volume
(Topic created on: 05-10-2020 06:41 PM)
Kaivu
Galaxy Note
For 2 days my incoming call volume has decresed significantly..when I shift to loudspeaker mode , it is ok. Kindly guide what to do.
7 Comments
AK070
Galaxy Note
phone ko reset koro
hedgehog
Galaxy Note
check speakers on interactive checks in members
reset phone clear cache
use Bixby routines
if call incoming then sound volume and media volume full or as desired
iamrohitkm
Galaxy Note
May be the volume might be low try to increase the volume and check .
Galaxy Note
Have you checked whether in call volume is full or not?
If not, then increase volume during call.
If volume is full then go for the interactive checks in members app.
Suraj82
Galaxy Note
Hi! please check if any dust is on your receiver. if yes then try to clean it with a dry & soft toothbrush. Hope it helps.
Dilli
Galaxy Note
Incoming calls through in ear speaker will always be low compared to speaker volume. It is made to work like this to avoid ear drums damage and health hazard.
cs_member9
Galaxy Note
Dear Samsung Member,
We at Samsung understand the situation as phone is one of the essential part of our day to day activity.
Kindly follow the below mentioned step to improve the performance of the device:
  1. Check device volume settings: Settings.> Sound & vibration.> Volume. Drag the volume adjustment bar left or right to increase or decrease the device volume.
  2. Check mute all sound option: Settings.> Accessibility.> Hearing enhancements.> Disable Mute all sounds (if enabled)
For further assistance, register your concern in Samsung Members Application (Samsung Members App > Feedback >Error report > Attach log file for any issue)
