in my note 9 am facing a problem displaying blinking while using power button
(Topic created on: 03-22-2021 10:06 AM)
subashini33
Galaxy Note
While using power button for screen lock displays is blinking can't able to use mobile what to do any idea. In series center they are telling to change display (16000)
5 Comments
Dilli
Galaxy Note
Yes display requires replacement, or you can sell and buy new phone.Goodluck
absrr2708
Galaxy Note
your phone manufacturer problems
Ehsank
Galaxy Note
better to visit service centre, and if they said it then no other option or help you will get remotely if you don't want to pay that much amount then only way is to local repair shop and obviously they will not use original display
Samsung_Support1
Galaxy Note
Dear Samsung Member,
We request you to kindly visit the service center for physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
surajsriram
Beginner Level 4
Galaxy Note
There is problem with the hardware it is happening due to recent software update
