charging problem with Note 9 4 months old
(Topic created on: 01-25-2019 10:52 PM)
water55
Galaxy Note
Samsung Galaxy Note 9 problem with charging
Pls help me out fixed this issue on my device. While connected to charged and charging icons appears on my device but won't charge up my phone battery wer as it's get charged using wireless charging what would be the issues pls help me guys n suggestions pls
7 Comments
NuClr
Galaxy Note
this is just a suggestion, pls try to change the charger and see, hope u hv spare charger,
water55
Galaxy Note
yap I did but still not working
thanks
Not applicable
Galaxy Note
check if the connector pins are damaged in the cable. or change the cable. most of the times it's the cable that causes problem after some time of use depending on the amount of usage.
water55
Galaxy Note
thank u but it's not working I did with 3to4 different cable but still not working
Same2018
Galaxy Note
go to Samsung service center
AmolS9
Galaxy Note
yeah, it won't even take an hr to replace the port. Also being in warranty he won't have to pay.
admin_
Galaxy Note
Thank you for being a part of Samsung community. We apologize for the inconvenience caused to you. We would like to inform you that this handset is enriched with the best available features. Kindly follow the below mentioned steps to overcome the issue:
1) We recommend you to charge your handset with original wall charger that came with your handset sales pack.
2) Check whether UPS (Ultra Power Saving) mode or PS(Power saving) mode is activated (if yes Deactivate it during charging).
3) Kindly clean the charging point of your charger and battery with a dry and soft cotton cloth to remove unwanted accumulated dust/waste material.
4) Kindly follow the standard charging procedure (Charge your device for 150 minutes on switch off mode).
If issue still persists, KIndly provide logs/video within 15 minutes of issue occurrence by registering this feedback via Samsung member application i.e. Samsung member BETA app> BETA feedback>Sendfeedback>Error report>Collect log files>attach.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you also connect us via Samsung Members web community by following mentioned url https://community.samsungmembers.com/en_IN#/
