charging and battery draining problem in note 10+ exynos version after oneui3.0
(Topic created on: 01-15-2021 11:20 PM)
Kunwar868
Galaxy Note
device showing cable charging instead of superfast charging with genuine charger and also charging v slow
battery drain issue SOT is just 3 hours .
6 Comments
Ehsank
Galaxy Note
If after update then wait for few days, and as of now perform these below steps;
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable/type C earphone only for Android 11)
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
C. Go to settings >general Management >reset>reset settings.
You can also send feedback to Samsung by using get help section
GetHelp>>SendFeedback>>ErrorReport/AskQuestion>choose appropriate section
Ehsank
Galaxy Note
and also I suggest you if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Samsung_Support1
Galaxy Note
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Galaxy Note
the stupid developers at samsung really ruined such a beautiful device with their unbaked android 11 one ui 3.0 update in india.so many complaints about all these issues & no fix even after releasing 2 security patch updates.disgusted!
Kunwar868
Galaxy Note
strongly agree 👍
Galaxy Note
i have a strong feeling that samsung is trying to adopt the apple strategy of ruining older flagships on purpose so we get rid of it in disgust & buy the newer flagships.what they don't realize is that there are more than enough of fish in the sea.so many other manufacturers who are providing way better stuff than samsung for half the **bleep** price.if this continues,my loyalty towards samsung will end soon!
