battery usage info vanished
(Topic created on: 01-03-2021 02:58 PM)
SAURAVMISRA
Galaxy Note
Any. N20U user seen this? The battery usage information disappeared from the system since 2nd jan.
17 Comments
Š
Galaxy Note
SAURAVMISRA
Galaxy Note
already done withese process, did not work.
Š
Galaxy Note
Then you have to wait for next update! It is happening to most devices which is on one ui 3.0
SAURAVMISRA
Galaxy Note
next update means, the public release of 3.0. for note20 series its probably on 16th
Š
Galaxy Note
Probably!
IndianMinion
Galaxy Note
I'm also facing this problem but, don't worry because it is a bug and this bug will fix by samsung in the next update.
Ehsank
Galaxy Note
if all done and not solved then send feedback to Samsung by using get help section
GetHelp>>SendFeedback>>ErrorReport/AskQuestion>choose appropriate section
SAURAVMISRA
Galaxy Note
thats done, and got an auto response as usual.
Ehsank
Galaxy Note
don't care about response, click on ask again and send continuously
