battery problem
(Topic created on: 10-30-2018 12:47 PM)
Choyi
Galaxy Note
I an using Note 8. Once the battery reaches 10%,  the mobile switch off and doesn't turn on. When I insert wire to charge, the display shows mobile is charginf from 0%. My mobile is 1 year old. Any help
6 Comments
uk29
Galaxy Note
r u using any battery saver mode?
Choyi
Galaxy Note
i am using battery saver mode ( Mid )
TuhinS
Galaxy Note
check for any abnormality battery issue in ur device maintenance. try to charge it before reaching 25%
YRSS
Galaxy Note
I refer u to change battery or do factory reset
NishitMehta
Galaxy Note
Check App Using More Ram And Uninstall it
Check The Storage Space Delete Unwanted Particles Or Move To Memory Card & Keep More Space to the Phone Storage
Change The Screen Resolution to HD+
And
Do The Following Steps
Setings》Device Maintenance 》App Issue Report》Click on App》Again Click on App》Uninstall
Do the Same With All App
And ReInstal Only From the Play Store or Galaxy Apps
This Will Solve Your Issue
And Keep Your Phone Updated
NishitMehta
Galaxy Note
If You Are Happy With My Answer Then Please Click On 3 Dot After My Comment And Click On Acpated Solution
