battery problem
(Topic created on: 05-05-2022 12:17 PM)
afnan001
Galaxy Note
Hi, I am Shraddha from Ridhiman Alloys.
I Have a problem of Battery draining fast within an hour.
5 Comments
Dhruv_0001
Galaxy Note
Which model are u using
Ab_Heartsy
Expert Level 3
Galaxy Note
The writer is a scammer 😵‍💫 profile.👆🏼
chndn811
Galaxy Note
May be your device's battery health is very low. Visit service center.
Ab_Heartsy
Expert Level 3
Galaxy Note
It's a scammer profile 👆🏼
cs_member8
Galaxy Note
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
