battery drain
(Topic created on: 03-02-2021 07:40 AM)
mrohitkanaujiya
Galaxy Note
After recent update in my note 20 ultra application named uwb eating too much battery.. Screenshot attached
5 Comments
S_Kumar73
Galaxy Note
If you installed Galaxy labs and Memory Guardian app, uninstall the apps. Then check.
Ehsank
Galaxy Note
under uwb all location based and file transferring system work like wifi Bluetooth and few more location based system
so do these few settings regarding this
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
Ehsank
Galaxy Note
Besides above settings do some more settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info (ibutton> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Not applicable
Galaxy Note
Reboot the handset
This is the quickest, easiest, and least destructive thing to try first. On most handsets you just press and hold the power button until the Restart option appears.
This isn't just a fix for poor battery life. It fixes most things most of the time!
Update your apps
Don't have your apps set to update automatically? A rouge app is a common cause for sudden and unexpected battery drain. Head over to the Google Play Store, update any apps that need updating (updates come around fast), and see if that helps.
Update Android
OK, I know. Depending on the maker, updates can either roll around on a regular basis, or be as rare as hen's teeth (which might not be as rare as Android updates on some handsets).
But it's worth a try -- fire up the Settings app and go System > Advanced and then either look for About phone or About tablet or System update or Wireless update. You may well have to dig about!
Nuke your settings!
This is the nuclear option because it will mean having to set up your phone again. Make sure you have a backup of your data before doing this.
Most people can access the reset options by firing up the Settings app and going System > Advanced > Reset options. However, some handsets require you to press the power button and some combination of the volume up or down to make this happen which you might find through trial and error (warning, this is frustrating!) or from an internet search.
Samsung_Support1
Galaxy Note
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
