battery drain
(Topic created on: 06-14-2020 02:08 PM)
Mysteriousboy
Galaxy Note
Note10 plus after june 2020 update battery is draining even more bad than before.
7 Comments
iamrohitkm
Galaxy Note
Wait for sometime it will get set and battery drain will reduce.
Mysteriousboy
Galaxy Note
are you sure as im really regretting to update to june patch because of battery drain issue.😭
iamrohitkm
Galaxy Note
Usually after any updates there will be battery drain issues for some days as the software has to get set. After sometime it will become proper.
iamrohitkm
Galaxy Note
In my S10 i feel battery backup is much better now after June update. Not facing any fast battery drain.
Samsung_Support3
Galaxy Note
Dear Samsung Member,
Please visit this mentioned link to resolve your device battery drain issue: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
KushalRaj
Galaxy Note
my note10 plus battery drains too much at night 15% 20% in 7 to 8 hours. And when I put the mobile on airplane mode at night my battery drians 5% to 10%
help needed
arunnechlani
Galaxy Note
