Resolved! Solved
Recovery mode issue on Samsung note 10 Plus
(Topic created on: 01-15-2021 01:25 AM)
ankushaggarwal
Galaxy Note
Dear Sir,
Samsung note 10 plus model is not going to recovery mode after Android 11 update. I have follow the process as shutdown then push volume up and power key at same time.
Got [PDP] BACK-UP :FAIL /C PARTITION SIZE
PLEASE DO NEEDFUL
4 Solutions
Galaxy Note
It changed with Android 11, now you need to plug the USB-C / micro-USB cable along with the combination buttons (Press & Hold the Power and Volume Up button)
you can enter recover mode by doing this
connect ur device to pc by usbc cable
and make sure ur device is visible in computer as logged in
turn off ur device with the cable connected to pc
and now hold power up and switch on button together until the recovery menu pops up
Ehsank
Galaxy Note
now you need to connect type c cable or earphone
Galaxy Note
If problem solved then click at 3 dots near my 1st comment and accept it as solution to help others
Samsung_Support1
Galaxy Note
Dear Samsung Member,
Please perform the below mentioned steps to go to android 11 recovery mode:
1. Connect USB cable to PC.
2. Power off the device.
3. Press VolumeUP + Bixby PowerKey Keys and hold them.
4. Connect the USB cable with device then, it'll enter recovery mode
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
10 Comments
Galaxy Note
Ehsank
Galaxy Note
Galaxy Note
Samsung_Support1
Galaxy Note
DarkevilPT
Galaxy Note
Seems like that after ONEUI 3.0 update not only recovery mode changed but battery drains like by the minute.. Im gonna try ti wipe it all clean before going to samsung.. this last update just messed things up.
yuvrajsekhar
Galaxy Note
The same problem to me no recovery mode.
And the screen started flickering while adjusting the brightness After update.
KindlyThrive
Galaxy Note
This does not work for my phone. When I hold the volume up and power button, it brings up a warning about loading a new operating system and how it will void my warranty. So frustrating. I have spent hours on this and I have only gotten in the  recovery mode once. I do not know why this is so **bleep** complicated.
Wolfheart
Galaxy Note
Hello,
I have had this issue for few months now and have tried all the methods mentioned here and else where but nothing seems to work and I can't wipe my cache.
I also do not want to reset to factory setting. So any bright or creative ideas to help me fix this issue plz Samsung and community?
Dennis_B
Galaxy Note
Hi samsung please help me. I cant enter the recovery mode with note 10 plus android 12.. i need it.. i hope you can help me. Thanks
