Note9 Battery Drain Solution .......
(Topic created on: 11-30-2018 04:11 PM)
MightyBeasty
Galaxy Note
Hi Note9 User,
I have cracked the solution for fixing Note9 battery drain issue.
Please navigate to Settings- Connections - Mobile Network .
Now please switch off *VoLTE calls SIM1*.
Restart your mobile once and enjoy your Note9 battery only for the activity you do.
This will fix the ANDROID SYSTEM service from drinking the mobile battery juice .
Hope this helps.
8 Comments
ZombieHRN
Galaxy Note
if u turn off VoLTE then how u gonna video call soneone directly from the sim or enjoy the HD and QUICK calls???
MightyBeasty
Galaxy Note
Bro probably Samsung should fix this issue ...
shubham425
Galaxy Note
bhai ye sabhi phone me kam karega kya e.g samsung on5 pro
manish7
Galaxy Note
no such option in my note9
gakshat14
Galaxy Note
this will actually disable your Jio sim, as they only rely on 4G VoLTE to make calls
MightyBeasty
Galaxy Note
Just check that provides solution. Hoping for Samsung to fix.
Sachin7
Galaxy Note
I will try
MightyBeasty
Galaxy Note
Sure.. pls let me know the result.
