Note9 Android Pie battery drain
(Topic created on: 02-19-2019 11:37 AM)
shubham1602
Galaxy Note
I'm facing severe battery drain issue on my Note9 after android Pie update. Anybody else facing this issue? I used to charge my phone after 24 hours earlier but now I've to charge it twice during day with optimized power setting enabled.
6 Comments
deepakdudhedia
Galaxy Note
cool
ChakhnaChor
Galaxy Note
Same here
aryan82
Galaxy Note
same here
drulers013
Galaxy Note
Same here. After Pie update, the battery drains without any heavy usage of apps.
pvijumar
Galaxy Note
yes to me also same problem
admin_
Galaxy Note
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members BETA App ->BETA Feedback > Send Feedback > Error reports > collect log file > Attach). Be sure to hit ♡ when you find an answer that works for you.
