Note 8 problem
(Topic created on: 10-05-2019 06:30 PM)
PrakharMishra
Galaxy Note
Dear All
I am using note 8 and from last two months I am facing problem of ping with cellular network while playing pubg ....But if i am putting same sim in other mobile and using it as hotspot device for my Note 8 game running fine ....This issue I am facing with pubg ...Recently I downloaded COD same problem ...Other apps working fine with cellular network ....Is this is hardware issue ,software issue or anything else .... Help me If any have some idea .
5 Comments
PrakharMishra
Galaxy Note
Bro I did the reset of both network and apps ...
xdgone
Galaxy Note
issue with game server and your ISP provider. track your ISP dns and tye game server IP address ping rate via any online test tool
ping ( technically LETANCY ) is all about server side element it has nothing to do with players device, if internet is not unstable
you will have many misleading solution like above over search .. but technically in computer server client network mechanism PING or LETANCY is all about how much time your ISP dns takes to game server to communicate or game server takes time to reach your ISP dns to communicate
do client reset first , than restrict background apps to use internet than use your game , if still there is ping issue , try online test of your ISP dns letancy rate to game server .. if all shows ok than contact the game developer to report the issue
test your ISP CAPACITY FOR MAINTAINING LERANCY OR PING for PUBG HERE
https://gameserverping.com/pubg
For gaming in pubg or cod the worst internet are JIO , AIRTEL etc ( some places are exceptional cause there they have low LETANCY load , celluar networks usually not stable as of its nature , i am mot talking about speed , its about LETANCY rate )
specially some internet providers do give high speed letancy with their connection apart from internet speed
PrakharMishra
Galaxy Note
Bro I can understand what u want to say but the problem is when I am putting that sim in another mobile there is no problem while playing with cellular network even on low end device ...Only this problem is happening in Samsung Note 8 ..Plz if u have any solution let me know...
PrakharMishra
Galaxy Note
I know well about latency but the same sim is working fine in another mobile in same area....
xdgone
Galaxy Note
than check your usage of internet traffics in your device , restrict them to save bandwidth
