Note 8 battery draining
(Topic created on: 02-03-2018 11:17 AM)
dhillon0058
Galaxy Note
Battery backup is getting pathetic. it's draining very quickly. Even in power saving mode it was 100% at night and wake up with just 40%. Any suggestions plz, to improve battery backup.
thanks
9 Comments
Vishesh_M
Galaxy Note
1)dont keep it on charging entire night
2) close apps which you are not using
AnkurBansal
Galaxy Note
These things dont matter.
darshan98
Galaxy Note
open battery usage and check for battery hungry app.
Then uninstall it
AnkurBansal
Galaxy Note
Disable sync and Always on display. That will do the trick. And turn off location as well.
dhillon0058
Galaxy Note
will try this one. thanks for the suggestion.
Sam619
Galaxy Note
As Said, Don't keep for charging whole night. it will be affect your handset battery life.
~Samsung_OS_Developers
dhillon0058
Galaxy Note
I don't charge it overnight.
admin_
Galaxy Note
"Thank you for Joining Samsung community. We would recommend taking some troubleshooting steps to further isolate what you may be experiencing.
Find troubleshooting steps on provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let the us know what steps you have taken and if you have noticed any changes or improvements. This will help the Community to provide you steps without repeating any steps you may have already taken. Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
PRANAY58
Galaxy Note
search for app that is responsible and make sure that u haven't installed apps from untrusted sources rather than in play store or galaxy store.
