Note 8 Sensor Problem solution
(Topic created on: 02-25-2019 03:09 PM)
pk95
Galaxy Note
Can anyone give a wise solution of sensor problem caused by samsung's update bug? I am badly in need a working solution....
15 Comments
HIRO
Galaxy Note
which sensor is not working in ur phone
pk95
Galaxy Note
iris, proximity, rotation,heart rate monitor & light sensor
HIRO
Galaxy Note
did u check this in *#0*
pk95
Galaxy Note
I check this in *#0*#. sensor hub test failed,sensor reading is zero.I t happen after January security update
pk95
Galaxy Note
I also factory reset twice. After reset once sensors work but after a while again stopped working
HIRO
Galaxy Note
bro hard rest your phone ...onces my s6 edge plus was also jot working back in 2015 thn i was scared n perform a hard reset then it was fixed
pk95
Galaxy Note
hard reset! You mean Factory reset?
HIRO
Galaxy Note
yes bro but hard reset
pk95
Galaxy Note
I did couple of time. Sensors worked for some time but again get stopped.I can't understand where is the problem either in the sensor or software issues...
