Note 20 ultra problems
(Topic created on: 11-22-2021 10:24 AM)
girisha123
Galaxy Note
I cannot set vibrate when answered in note 20 ultra while a lower end mobile of samsung supports it.. what sort of **bleep** is this.
Please raise this concern so that it gets fixed.. lot of basic things are missing is there a forum where this can be raised and get them addressed ?
2 Comments
MuzikD
Expert Level 3
Galaxy Note
Check your settings once...
I use this mobile too and it works perfectly.
Settings:
Open keypad dial
Go to call settings
Go to call alert and ringtone
Set your preference... Restart the mobile... Screenshot_20211122-123017_Call settings_127865_1637564417.jpg
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung Member,
We apologize for the inconvenience you are facing. We understand your concern and help you resolve this. Kindly perform some quick troubleshooting steps to resolve your issue:
Go to the home screen >> Tap on settings >> Tap on sounds >> Select vibration >> Turn it on.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
