Note 10+ spen disconnected problem
(Topic created on: 12-11-2022 01:26 AM)
SBA2020
Galaxy Note
Continuously showing disconnected problem , any solution????
7 Comments
S_Kumar73
Galaxy Note
You have to check is there any damages in SPen. Hope you already did "reset S pen" as shown in the attached screenshot. If not try once. Even it's not connected then its SPen fault. You have to go to service center for physical inspectionScreenshot_20221211_054915_Air command_1000065274_1670717955.jpg
SBA2020
Galaxy Note
Try all this same problem
VRao
Galaxy Note
For me it happened once on another note.. A toggle to airplane mode n back fixed it..
SBA2020
Galaxy Note
Ok
Sanaaz
Galaxy Note
It must be s pen problem so s pen will be change
SBA2020
Galaxy Note
I think so
cs_member8
Galaxy Note
Dear Samsung member,
How to Reset S Pen
Please follow the below steps:
Step1: Navigate to the Apps screen and tap on Settings.
Step2: Tap on Advanced features.
Step3: Tap on S Pen.
Step4: Tap on Air actions.
Step5: Tap on More.
Step6: Tap on Reset S Pen.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
