Not able to activate Maximum power saving mode on note 9 after Android 10 update
(Topic created on: 01-05-2020 05:25 PM)
Kapilharmilapi
Galaxy Note
I am Not able to activate Maximum power saving mode on note 9 after Android 10 update. Medium power saving can be activated. Anyone facing this issue. Please confirm.
5 Comments
Samsung_Support1
Galaxy Note
Hi there,
In order to examine the issue occurring in your device kindly send device log file with screenshot within 15 minutes of issue occurrence along with the exact issue details, using Samsung member application i.e. Samsung member app > Click on + icon > Send feedback > Error report > Collect log files > attach.
Regards,
Team Samsung Members
rvk93
Beginner Level 3
Galaxy Note
same issue. note 9
VijjuVj
Galaxy Note
I too facing same ossie in my S9
Merrymart
Galaxy Note
I have same problem on my S10.
Options for turn off Always On Display is switched on, but greyed out. Limit CPU speed to 70% is switched on but greyed out. Decreased brightness is switched on, but greyed out.
Limit apps and Home screen is switched off and greyed out.
All the greyed out features cannot be changed.
Overnight, i used to switch on max power saving, this meant no stupid emails or whatsapps at stupid oclock, and save my battery.
Can you fix this please.
Martin
Merrymart
Galaxy Note
OOOPS, just read the following
Note: In order to turn these options on or off, Power saving mode must be disabled. Once you've made your desired adjustments, you can turn Power saving mode back on.
