My Note 5's battery is drainage very fast..HELP!!!
(Topic created on: 03-18-2017 11:19 PM)
Arpit164
Galaxy Note
Battery of my Note5 lasts only 3-4 hrs on screen on time which was earlier 7-8 hrs, why ?? This happed in last 10 days, i am so confused why is it happening. I am using original provided Adapter and 3rd party cable (original fast charging supported) and always update the software to the latest posible.
Help me out guys
5 Comments
Bhaiya
Galaxy Note
bro i also have a note 5 and my battery is quiet decent.you may working too on mobile with high internet usage so might be one issue otherwise drainage is not possible without extended usage
nitinydv
Galaxy Note
go to settings and search nearby device scanning and turn it off . after the latest update it got turned on automatically i think i had the same problem now its solved.
riju
Galaxy Note
thanks man helped a lot
Arpit164
Galaxy Note
thankyou
Samsung_India_
Galaxy Note
"Thank you for Joining Samsung community. We would recommend taking some troubleshooting steps to further isolate what you may be experiencing.
Find troubleshooting steps on provided link http://www.samsung.com/in/support/skp/faq/1101689"
