Maximum Power Saving Mode
(Topic created on: 04-30-2019 04:43 PM)
Livelywispy
Galaxy Note
Does anyone else have problems like App icons disappearing or Folders disappearing or System Apps behaving weirdly after using Maximum Power Saving Mode on Note 9 and require to restore the phone from a previous Backup?
8 Comments
KSNR
Galaxy Note
Sachin-S20FE
Galaxy Note
yes I also face the problem when maximum power saving mode used
PanPerfect
Galaxy Note
maximum power saving mode, will be used when ur running out of battery. in this mode, ur apps are disabled. pls exit the mode to medium power saving mode r optimized power mode. it's not a problem or anything
Livelywispy
Galaxy Note
the problem comes 'after' exiting the mode it's fine as long as I don't use it but if I do my apps glitch and icons are disappear
Livelywispy
Galaxy Note
the phone stays okay in Optimized mode and while in any other mode but the problem comes when changing from Maximum saving to normal mode. it isn't supposed to remove icons on home screen and remove folders from Apps screen and supposed to go back to exactly how it was before I turned on power saving mode but it doesn't, that isn't something it shouldn't be doing
PanPerfect
Galaxy Note
better do once factory reset.
Livelywispy
Galaxy Note
this happened after reset was fine before that
PanPerfect
Galaxy Note
wait for another uodate
