GALAXY note 10 Plus Battery is draining after Android 12 Update
(Topic created on: 02-03-2022 01:55 AM)
Shaan1309
Galaxy Note
Hi, This is just to ask you all if anyone is having the same issue like me.. After I update my device to android 12. I am facing battey backup issue.  My phone's battery is draining like water. It lasts only 6 hrs max. Earlier i use to use my phone atleast 12 to 13 hrs.
Please suggest and advise if anyone if you have any resolution.
SAMSUNG PLEASE FIX THIS WITH AN UPDATE.
11 Comments
Laxy1
Beginner Level 3
Galaxy Note
Me to, I had a good battery life before the update, the battery drain is significantly more.
lion_kg
Galaxy Note
The same for me. Battery drain entreated drastically. Tried everything, optimizing, turning off connectivity and smart features etc. Samsung, please fix this!
