Connectivity issue between Note10 Lite and Sony TV through NFC
(Topic created on: 04-20-2020 12:00 PM)
AJDD
Galaxy Note
unable to connect samsung note 10 with sony TV through NFC. While connecting, it asks - complete action using "New tag scanned". After clicking it, phone displays two tags:
(1) vnd.android.nfc://ext/sony.com:wfp2p
(2) vnd.android.nfc://ext/sony.com:wt
Nothing happens thereafter and TV times out waiting for the connection
17 Comments
Not applicable
Galaxy Note
hm then why its not getting connected if its still present it does not requires and special app for that , if it requires then download the app of that tv
Not applicable
Galaxy Note
then why its not getting connected with the tv
AJDD
Galaxy Note
Thanks buddy ... not sure whats the issue
Aashish
Expert Level 4
Galaxy Note
Bro you can manually change NFC modes and try? You find NFC in Connection settings and 3 dots on the right.
AJDD
Galaxy Note
No three dots to manually change the setting in my device. Under Connections -> NFC and payment -> 3 options of (a) NFC on/off, (b) Android Beam on/off and (c) Tap and Pay. Thats it.
Aashish
Expert Level 4
Galaxy Note
Ok bro so I read about this. This is a one touch screen mirroring function which utilized Miracast, Unfortunately we no more find Miracast on latest devices so there may be a problem in connecting to it.
AJDD
Galaxy Note
Thanks buddy ... your observation may be correct. Is there any tool to diagnose the problem?
cs_member9
Galaxy Note
Dear Samsung Member,
Smart View: The app that lets you enjoy multimedia content from your mobile and PC on your Smart TV. You can also share multimedia content from your mobile and PC on your Samsung Smart using this app.
Kindly follow the below mentioned step to improve the performance of the device
Swipe down the Notification panel>>Select screen mirror option (Smart view / Mirroring / Miracast / Wireless Display / Mirror Share / Screencast / Screen Share / Smart View/play to, etc.)>>Enable Smart view>Select the desired device. >>Tap to connect TV model no>>Notification bar will appear on the TV screen and select Allow to give permission to connect your device.>>Phone is connected with TV. Now you can share the mobile content with TV
Note: You need to have the mirroring connection to be open on both your smartphone/tablet and the TV for the mirroring to work correctly.
Please click on the below mentioned link for further details:
https://www.samsung.com/in/support/smart-view/
Note: In case if the issue still persist please contact your television provider
For further assistance, register your concern in Samsung Members Application (Samsung Members App > Feedback >Error report > Attach log file for any issue)
